The below irule does not Bypass SSL forward proxy function for url’s defined in the Bypass datagroup, it continues to re-sign with the certificate provdied by F5…
when CLIENTSSL_CLIENTHELLO {
if { $static::DEBUG } { log local0. "in event" }
set sni_exists [SSL::extensions exists -type 0]
if { $sni_exists } {
binary scan [SSL::extensions -type 0] @9a* tls_servername
if { $static::DEBUG } { log local0. "tls_servername = ${tls_servername}" }
when CLIENTSSL_SERVERHELLO_SEND {
if { [class match $tls_servername contains Bypass] } {
log local0. "Data group match"
SSL::forward_proxy policy bypass
HTTP::disable
pool bluecoatpool
On of the primary issues here is timing. In your iRule, you’re redirecting traffic to the bluecoat pool in the CLIENTSSL_SERVERHELLO_SEND event. Presumably you have another pool that is default for traffic.
When a client enters the SSL forward proxy VIP, he’ll initiate the SSL handshake.
Client Hello
which is then paused. At that point, the server side goes out and performs a complete server side TCP connection and server side SSL handshake with the server, brings the server’s cert back, and only then does the client side SSL session resume.
client side server hello send
So by the time you get to the CLIENTSSL_SERVERHELLO_SEND event, an initial server side connection has to have already left through the default path, so setting the pool in this event is too late. Try this:
pool bluecoat-pool
catch { HTTP::disable }
