I want to enable/disable SSL based on SSL Cipher version. I have created the following iRule, but it does not work as expected.
when CLIENTSSL_CLIENTHELLO {
log local0. "[SSL::cipher version]"
if { [SSL::cipher version] <= "TLSv1.2" } {
SSL::disable
pool pool_1
else {
SSL::enable
pool pool_2
I confirming that traffic forward with the specified Pool.
Could you tell me how to make the expected behavior?
