SSL Connection failing alternatively
Hi All,
We have a problem with only one service in the virtual server that internal user complained that SSL connection fails to him alternatively. when he tries to hit a URL from a server. We are doing SSL bridging. and using the default serverssl as profile on server-side. and since the server is configured to use the ssl we are disabling in that using the irule.
“/xyz*” { SSL::disable serverside snat 10.x.x.x use pool /Common/XYZ_pool
I tried couple things but none of those are worked. Appreciated if any one helps in figuring out this issue.
Thanks,
You are using both ssl-client profile and ssl server profile for your application? Can you please provide your virtual server configuration
