SSL connection fail: basic constraints check failed: this is not a CA certificate
Hi guys, I have a problem with https connection via F5:
(MY SERVER/ APP) ---https request----> F5 (irule which copy auth info to header) ------http request---> another app
Ive created keystore (jks file) on MY SERVER/ APP (using java keytool):
keytool -genkey -keyalg RSA -alias myAliasSelfSigned -keystore keystore-client.jks -storepass password -validity 7200 -keysize 2048
I`ve created VIP which use SSL Profile (client) with settings: Parent clientssl, certificate: default, Key: default, Chain : default, Trusted Certificate Authorities: default
Client Authentication: Client Certificate: request, Frequency: once, Cert Chain Traversal Depth: 9, Advertised Certificate Authorities: None.
After request from MY SERVER/ APP to F5 I get an exception: java.security.cert.CertPathValidatorException: basic constraints check failed: this is not a CA certificate
What is wrong with my configuration?
As per error, it seems you need to install cert n root cert at Oracle/soa application filestore. Please do the debug at server side n get the exact location and install certificate and bounce service.. Hope issue will solve.
I dont understand how can I install cert/root cert at Oracle app filestore. I`ve already created keystore on my app using keytool. I think the problem is not trusting F5 to my configuration. Am I right?
I generated only keystore (
keytool -genkey -alias tomcat -keyalg RSA -keystore /keystore-location
-storepass password
) I didnt create Certificate Request and send it to CA
You need to push cert to Oracle/SOA
keystore-client.jks
violet & issue will solve. Its not the issue of F5 configuration. Issue exist with Backend server..
Which cert do you mean? cert from F5?
What ever cert you are applying on F5 same to be applied on application level.
I have properties file in my application level and keystore-client.jks is pushed into my spring application in every start. It is tested without F5 and works OK. I have no idea why it doesnt work via F5
