Hi Vernon! thanks for your help. i need it for SSL offloading. i have tested a website that got grade A on ssllabs/ and i saw that his result was: LS_RSA_WITH_3DES_EDE_CBC_SHA (0xa) 112 TLS_RSA_WITH_AES_128_CBC_SHA (0x2f) 128 TLS_RSA_WITH_AES_128_CBC_SHA256 (0x3c) 128 TLS_RSA_WITH_AES_128_GCM_SHA256 (0x9c) 128 TLS_RSA_WITH_AES_256_CBC_SHA (0x35) 256 TLS_RSA_WITH_AES_256_CBC_SHA256 (0x3d) 256 TLS_RSA_WITH_AES_256_GCM_SHA384 (0x9d) 256 can you help me write that string ?
Unfortunately you’re best bet is probably to patch. Any workaround cipher string will severely limit access to older clients. On an 11.6.0 box the DEFAULT stack should get you a B.
