cymru81
1
Hi, we currently use the following ssl ciphers to secure traffic to a VIP on our LTM:
!COMPAT:!LOW:!SSLv2:!SSLv3:!MD5:!SHA:!DES:!DHE:!EDH:!EXPORT:ECDHE:RSA:RSA+3DES:!TLSv1
how could we enable TLSv1.1 in this list (but not 1.0) and all others stay the same?
P_K
2
Looks like your cipher list only blocking TLSv1.0 not TLSv1.1. Which version of Big-IP you’re running? TLSv1.1 is available from v11.x
If you’re on 11.x or above, you shouldn’t be blocking TLSv1.1 unless your cipher list have
!TLSv1_1
Hope this helps!
