SSL Chain Certificate Installation on Big Iq5.0
Hi All,
It looks like the intermediate certificate installation can no longer be done from GUI on Big Iq5.0 . I tried to carry on this task from CLI but still no luck. Can any one in the forum help me with this installation.
Many Thanks, SSK.
Replace /config/httpd/conf/ssl.crt and /config/httpd/conf/ssl.key with your cert and issue tmsh restart sys service webd from the command line.
Kyle,
Thanks for the response. I belive you wanted met to replace server.crt and server .key files. When I do this , webd dameon goes restart mode until I revert my changes. Any idea what the issue can be.
SSK
