I have a VIP with a Verisign certificate configured on it. The VIP listens on port 443, and the Reals/Members listen on port 443. It has been requested to have a self-signed cert on the Server (The Reals) in addition to the Cert installed on the VIP.
My Question:
A self-signed cert has been configured on the server. Is there anything I need to do on the F5 side?
The minimum on the F5 side is to add server_ssl to the VS so that it will negotiate the SSL/TLS when it connects to the servers. That should work as it is. If you require any options on the server_ssl then create a new server ssl profile, using the server_ssl as a parent and just over-ride the changes in the new profile configuration (Then add the new profile to the VS).
If you already have a custom server ssl profile on your VS then you MAY need to alter it, depending on what is set. But the default one should work fine.
So from a configuration perspecitve, assuming this is a basic SSL config on the server side, I just need to enable the default SSL Server Profile (serverssl) on the VIP?
So by enabling the Server profile does this basically ‘turn on’ encryption for the F5-to-Real_Server communication? Even tho the server listener is 443, its not encrypted until you enable Server side SSL?
Nothing will happen unless you are using a server SSL profile which checks for the server cert validity. The client SSL session is independent of anything on the serverside. As long as the serverside connection can be established, the client will not be impacted by anything related to the SSL handshake on the serverside. If the server SSL profile has a server cert set to require, I expect LTM would not complete the serverside handshake and the clientside connection would be timed out or closed.
I used the default Server SSL Profile called ‘serverssl’. Is ‘server cert validity’ disabled by default? What option/setting would identify the state of cert validity checking?
It’s under the server cert section on the server SSL profile. If you change Server Certificate from the default of ‘ignore’ to ‘require’, LTM will check the start and end dates of the cert and not complete a handshake for an invalid cert. You can also configure a name to look for in the common name field of the server cert. If you want LTM to check the client cert issuer, you can configure a trusted CA cert bundle in the server SSL profile.
No, the standard serverssl profile will do. The cert (just like when your browser accesses a site) will pass the certificate to the LB, and rthe serverssl profiles is pretty lenient, meaning self-signed and expired certs are accepted.
