"SSL::cert mode require" does not work
I’m trying to use an iRule to perform client certificate authentication on certain parts of my website and not others. I found this article to use a starting point: DevCentral
Everything seems to work except for the “SSL::cert mode require” line. The browser (and a packet capture confirms it) never receives a request from the F5 for its client certificate. The ltm log shows the following after a failure:
May 11 14:13:06 4000s-1 info tmm[15688]: Rule /Common/test-by-uri-cert-auth : Protected URI requested: /protected/index.htm May 11 14:13:06 4000s-1 info tmm[15688]: Rule /Common/test-by-uri-cert-auth : No Certificate Provided
The iRule is:
when HTTP_REQUEST { if { [HTTP::uri] starts_with “/protected/” } { log local0. “Protected URI requested: [HTTP::uri]” if { [SSL::cert count] <=0 } { HTTP::collect SSL::authenticate always SSL::authenticate depth 9 SSL::cert mode require SSL::renegotiate } } }
when CLIENTSSL_CLIENTCERT { HTTP::release
if { [SSL::cert count] < 1 } { log local0. “No Certificate Provided” reject } }
how’s your client ssl profile configured?
All defaults except for the Trusted and Advertised CAs. If I set Client Certificate to “request” in the SSL profile then the browser starts complaining about “ERR_SSL_VERSION_OR_CIPHER_MISMATCH” (chrome) or “Turn on TLS 1.0, TLS 1.1, and TLS 1.2 in Advanced settings and try connecting… again” (IE).
Problem solved. Setting Client Certificate to “request” in the SSL client profile was the right move. Once I resolved the browser errors (which were totally misleading) everything started working as expected. I still don’t understand why “ignore” seems to overwrite the “SSL::cert mode require” statement in the iRule.
As for the browser errors, they were entirely misleading. I discovered in the log this error which led me to the real solution: - Illegal argument. Can’t execute in the current context. (line 1) invoked from within "HTTP::release "
In some cases my iRule was trying to run HTTP::release when HTTP::collect had never run. I solved that problem by just tracking when HTTP::collect was run and only running HTTP::release in those cases.
The working iRule is:
when CLIENT_ACCEPTED { set collected 0 }
when HTTP_REQUEST { if { [HTTP::uri] starts_with “/protected/” } { log local0. “Protected URI requested: [HTTP::uri]” if { [SSL::cert count] <=0 } { set collected 1 HTTP::collect SSL::authenticate always SSL::authenticate depth 9 SSL::cert mode require SSL::renegotiate } } }
when CLIENTSSL_CLIENTCERT { if { $collected eq 1 } { HTTP::release } if { [SSL::cert count] < 1 } { log local0. “No Certificate Provided” reject } }
Another update: With the change to “request” I needed to make sure un-protected URIs didn’t get rejected during CLIENTSSL_CLIENTCERT so I added an if statement to only check for a certificate for protected URIs (tracked by the $protected variable). when CLIENT_ACCEPTED { set collected 0 set protected 0 } when HTTP_REQUEST { if { [HTTP::uri] starts_with “/protected/” } { set protected 1 log local0. “Protected URI requested: [HTTP::uri]” set collected 1 HTTP::collect SSL::authenticate always SSL::authenticate depth 9 SSL::cert mode require SSL::renegotiate } } when CLIENTSSL_CLIENTCERT { if { $collected eq 1 } { log local0. “HTTP release” HTTP::release } if { $protected eq 1 } { if { [SSL::cert count] < 1 } { log local0. “No Certificate Provided” reject } else { log local0. “Certificate Provided!” if { [class match [X509::serial_number [SSL::cert 0]] equals test-serial-num-list] } { log local0. “Client Accepted - IP:[IP::client_addr] Serial:[X509::serial_number [SSL::cert 0]]” accept client cert } else { log local0. “Client Rejected -IP:[IP::client_addr] Serial:[X509::serial_number [SSL::cert 0]]” reject } } } }
