SSL Authentication issues
Our method is to have them purchase a cert from an authority (although we’re trying to get self-signed certs to work for initial testing), give us the serial of that cert and we’ll put it in a Data Group List that our iRule checks. So we’ll check for a valid cert and that it matches our list of serial s. Below is the iRule as it is now and a screen capture of the section of the SSL Client profile I was talking about.
Some scratch notes from last night’s testing:
In Stage Environment:
if we request client cert, clients with no cert come through
if we require client cert, passes to iRule and valid clients are rejected
IE8 get through
Firefox does not get through
iRule - ncf-tls-poc.443
when CLIENTSSL_CLIENTCERT {
if { [SSL::cert count] == 0 } {
log local0. “No Client Certificate Provided - IP:[IP::client_addr]”
drop
else {
log local0. “Client Certificate Recieved - IP:[IP::client_addr] Serial:[X509::serial_number [SSL::cert 0]]”
if { [class match [X509::serial_number [SSL::cert 0]] equals ncf-tls-poc.443-ValidCertificateSNs] } {
log local0. “Client Accepted - IP:[IP::client_addr] Serial:[X509::serial_number [SSL::cert 0]]”
else {
log local0. “Client Rejected - IP:[IP::client_addr] Serial:[X509::serial_number [SSL::cert 0]]”
reject
it seems to be okay on my firefox.
[root@ve1023:Active] config  b virtual bar list
virtual bar {
   snat automap
   pool foo
   destination 172.28.19.79:443
   ip protocol 6
   rules myrule
   profiles {
      http {}
      myclientssl {
         clientside
      tcp {}
   vlans external enable
[root@ve1023:Active] config  b pool foo list
pool foo {
   members 200.200.200.101:80 {}
[root@ve1023:Active] config  b profile myclientssl list
profile clientssl myclientssl {
   defaults from clientssl
   ca file "ca.crt"
   peer cert mode require
[root@ve1023:Active] config  b class ncf-tls-poc.443-ValidCertificateSNs list
class ncf-tls-poc.443-ValidCertificateSNs {
   "01"
[root@ve1023:Active] config  b rule myrule list
rule myrule {
                log local0. "No Client Certificate Provided - IP:[IP::client_addr]"
                drop
                log local0. "Client Certificate Recieved - IP:[IP::client_addr] Serial:[X509::serial_number [SSL::cert 0]]"
                if { [class match -- [X509::serial_number [SSL::cert 0]] equals ncf-tls-poc.443-ValidCertificateSNs] } {
                        log local0. "Client Accepted - IP:[IP::client_addr] Serial:[X509::serial_number [SSL::cert 0]]"
                        log local0. "Client Rejected - IP:[IP::client_addr] Serial:[X509::serial_number [SSL::cert 0]]"
                        reject
        log local0. "[IP::client_addr]:[TCP::client_port]|[HTTP::header User-Agent]"
when HTTP_RESPONSE {
        log local0. "[IP::client_addr]:[TCP::client_port]|[IP::remote_addr]:[TCP::remote_port]|[HTTP::status]"
[root@ve1023:Active] config  cat /var/log/ltm
Nov 18 09:08:46 local/tmm info tmm[24220]: Rule myrule : Client Certificate Recieved - IP:192.168.204.7 Serial:01
Nov 18 09:08:46 local/tmm info tmm[24220]: Rule myrule : Client Accepted - IP:192.168.204.7 Serial:01
Nov 18 09:08:46 local/tmm info tmm[24220]: Rule myrule : 192.168.204.7:53485|Mozilla/5.0 (Windows; U; Windows NT 6.1; en-US; rv:1.9.2.24) Gecko/20111103 Firefox/3.6.24
Nov 18 09:08:46 local/tmm info tmm[24220]: Rule myrule : 192.168.204.7:53485|200.200.200.101:80|200
For some reasons clients arent getting dropped when they dont match the datagroup …
For some reasons clients arent getting dropped when they dont match the datagroup … Thanks for the response :slight_smile:
