I think this is an issue specific to SSHD--not much of anything to do with BIG-IP. You could try searching the web for this error message. There are quite a few forum posts with troubleshooting suggestions. You could try running a new instance of sshd with debug enabled:
and then connect on port 2200. Or you could change the LogLevel in /config/ssh/sshd_config to debug, reload the config using kill -HUP `pidof sshd`and then retest.
Here are some related links:
I suspect you’re hitting the MaxStartups unauthenticated connection
limit. It default is 10, try bumping it on the servers to, say, 30 or 40.
> Hi,
> I’m getting this error when I ssh to the servers.
> ssh_exchange_identification: Connection closed by remote host
> I added /etc/hosts.allow and it actually worked once and if I tried again I get the same error.
You did not mention whether you added by name or by IP.
Every time I’ve seen this error it has been a DNS problem. And I only
see this on systems that are in hosts.allow by name.
I just wanted to add my comment on this old thread because I ran into similar issue when I was synchronizing FIPS Security Domain “ssh_exchange_identification: Connection closed by remote host” and was able to fix it by going to system>platform>ssh IP allowed: ensure the the peer ip address is added or “select allow all”
If you are trying to connect to self IP (no managment IP) on LTM running V10, it may fails on the non default route-domain. I faced such issue when exchanging key with a GTM (bigip_add). Afterward, the iquery connection can use any self ip.
