We have recently migrated few applications from old F5 boxes to the new F5 boxes.
Before migrating, the ssh login was working well (i.e. we were not getting any session timeout while logging using putty client). After migration, If we keep the ssh session idle (using putty & user login) for more than 5 mins it automatically get disconnected.
We need to understand if there is any setting available behind F5, to get this issue resolve.
To highlight here is that HTTP applications are working normally as before.
If you choose to use George’s solution (which will work also, but means you need to change all of your clients), still keep in mind that each VIP has a TCP profile bound to it and TCP behaviors are tunable per vip. By default we use a 5 minute (300 seconds) idle timeout value. To fix this, simply create a new TCP profile for this virtual server and change the idle timeout to something that makes sense for your environment.
This is a common issue for FTP as well - the control channel will time out during large transfers. But I digress.
