Hello Everyone…
I am sure that someone somewhere out there has had similar experiences to me!
We have a number of HTTP/HTTPS Proxy Server Pools (SQUID) for which we would like to implement persistence.
All incoming client requests to the Proxy servers come to a fixed IP on port 80 (i.e. ALL HTTP and HTTPS).
I would like to implement an iRule to send all traffic destined for HTTPS sites to a pool of Proxy Servers using SSL Persistence and all traffic destined for non-encrypted / HTTP sites to use Cookie (Insert) persistence.
Obviously - This will not work as I am unable to see the HTTP Headers for the SSL traffic.
rule split_http_https_by_pool_v4 {
if ( exists http_header “SSL Session ID” ) {
use pool HTTPS_Pool }
else
use pool HTTP_Pool
I’ve also tried using the http_method as the differentiator but get SSL errors in /var/log/bigip…
iRule:
if (http_method matches_regex “CONNECT”) {
log local0.info “https trigger”
use pool HTTPS_Pool
else {
use pool HTTP_Pool
bigip log errors:
Jul 5 18:14:56 BLAHBLAH kernel: RULE TEST_CONNECT - https trigger
Jul 5 18:14:56 BLAHBLAH kernel: SSL2: Message type is not a client hello
Jul 5 18:14:56 BLAHBLAH kernel: SSL3: Content type not a handshake.
Through this rule, HTTP sites work fine but HTTPS is broken.
I am finding it hard to find a generic way of differentiating between SSL and non-SSL traffic. Does anyone have any suggestions as to another approach I could use?
Many thanks in advance for any help / insight / assistance you are able to provide.
Cheers
SM
