Hi!
We’re using an irule to handle access to a webservice.
The irule matches the client certificate DN against a list of allowed DNs, and is the only irule assigned to the VIP.
After upgrading from v10.2.0 to 11.2.0 we’re occasionally getting this error in /var/log/ltm
tmm err tmm[7146]: 01220001:3: TCL error: /Webservices/certificate_verify_irule - can’t read “client_cert_ok”: no such variable while executing “if {$client_cert_ok == 0} { HTTP::respond 403 content “Bad client certificate! ($subject_dn)” set client_cert_ok 0 }”
The error complains about not beeing able to read the variable client_cert_ok, but works most of the time.
Searching the forums I found this post (TCL Error:no such variable while executing)
The replies there talks about RULE_INIT, but in this case, putting client_cert_ok in RULE_INIT will make it global, right? And I need it to be “local” for each client.
Appreciate all tips on how to solve this.
I have a vague idea that it might be CMP related, but I’m not that skilled in irules to see if there’s cmp issue with this one.
Thanks!
/Andreas
Derived from https://devcentral.f5.com/wiki/default.aspx/iRules/ClientCertificateCNChecking.html
when RULE_INIT {
when CLIENTSSL_CLIENTCERT {
init allowed/disallowed flag
default not allowed.
Check if client provided a cert
if {[SSL::cert 0] eq ""} {
log local0. "No client cert presented!"
Reset the connection
reject
Get the subject DN from cert.
set subject_dn [X509::subject [SSL::cert 0]]
Check trusted certs.
switch -glob [string tolower $subject_dn] {
"...DN1..." -
"...DN2..." {
Client cert is allowed. Set flag.
set client_cert_ok 1
log local0. "Matching client cert: $subject_dn | Client='[IP::client_addr]'"
default {
log local0. "NO MATCHING CLIENT CERTIFICATE!: $subject_dn | Client='[IP::client_addr]'"
reject
Client sent an HTTP request.
check if the client cert for this connection was trusted.
if it was not, send an error message to the client.
HTTP::respond 403 content "Bad client certificate! ($subject_dn)"
