I have a customer that wants certain traffic to the same VIP handled 2 different ways:
You have the entire URL (Ex: bobsdonuts.krispy.krm ) in pass through where we only need a subset of this in pass through (Ex: bobsdonuts.krispy.krm/config/baseurl.asp). As example the operators access the web page from the bobsdonuts.krispy.krm and get put into the bobsdonuts.krispy.krm/client/… portion of the site. The operator and the client connection are two different paths
Is this possible to do using the same VIP? IS there an access policy path that can achieve this?
I have customized one of my VIPs to allow this: domain.com/xyz/* authenticated domain.com/xyz/eao.aspx no authentication.
I have achieved this with irules. Is this what you are looking to do?
Yes, that is exactly what we are looking to do.
I recommend having a look at the Microsoft Exchange Server deployment guide. That’s where I found a solution.
To get the one that is optimized for you TMOS version go to > Support > Documentation > BIG-IP LTM > Your Version Deployment Guides > Microsoft Exchange Server 2010 and 2013 (BIG-IP v11 - v13: LTM, APM, AFM)
Basically it is the following with an added layer of security.
if { [string tolower [HTTP::uri]] equals "/xyz/eao.aspx" } {
ACCESS::disable
If you do not want to have to look up the code for Exchange:
priority 1
set is_disabled 0
switch -glob [string tolower [HTTP::path]] {
"/ews/mrsproxy.svc" -
"/ews/exchange.asmx/wssecurity" {
set is_disabled 1
set path [HTTP::path]
ACCESS::disable
HTTP::path _disable-$path
pool
"/autodiscover/autodiscover.svc/wssecurity" -
"/autodiscover/autodiscover.svc" {
set is_disabled 1
ACCESS::disable
pool
when HTTP_REQUEST_RELEASE {
if { [info exists is_disabled] && $is_disabled == 0 } { return }
if { [info exists path] } {
HTTP::path $path
unset is_disabled
unset path
I can’t claim to comprehend all the commands, however, it is about not giving access to more than the specified URL. One thing to note is the -glob command in the switches
-exact
Use exact matching when comparing string to a pattern. This is the default.
-glob
When matching string to the patterns, use glob-style matching (i.e. the same as implemented by the string match command).
I hope this will help you on your way
