It is a common pattern when doing rolling restarts/changes to members of a HTTP pool to take a member out of service, wait for connections to drop to zero, then do your maintenance there and put it back in the pool. However, because of http keep-alive I assume, it often takes minutes for HTTP client connections to drain even if they are not very active. I’d prefer not to disable http keep-alive entirely. Is it possible to set a profile, monitor, or iRule that would force keep-alive: close to be sent to clients connected to pool members that meet the criteria (monitor test failing, static page returns certain string, etc)?
More than HTTP Keepalive, it is the persistence that could cause connection to last longer on a pool member. You can use “forced-offline” or “reselect” option within the pool to select another pool member, if your application can handle the transition.
The oneconnect profile w/Reselect action on service down was a good solution. Thank you!
Welcome ! ![]()
