mgmt interface/ip is always available while tmm interface/selfip is not. for instance, while booting bigip, tmm might not be ready fast enough and ha pair might end up with active-active if only selfip is configured in unicast pair since unit is not able to reach peer’s selfip.
and for this to be useful , should the management interfaces sense each others ( be connected at same switch for example ) it is not required to connect them to the same switch.
also what if i did not put the entry for mgt , will HA work fineyes, it may work even not having mgmt ip in unicast pair but it might not work in some condition too. so, the best practice is to configure it.
can u give me any good example for example, in ha pair, if we reboot unit1, unit2 will be active. in case if redundancy state preference is none, unit1 won’t preempt an active role when coming back. anyway, if sod process is ready before tmm, sod may force unit1 to be active since unit1 is not able to communicate to unit2 via tmm interface/selfip.
