Specify port number in iRule?
Can you specify a port number in addition to local or remote IP addresses in an iRule?
Per the BIG-IP 9.0 reference manual, chapter 13, here is the syntax for the rule statement command:
[use] node [] Causes the identified server node to be used directly, thus bypassing any load-balancing.
Here’s a Link to the manual. You will need your F5 support password to access this resource.
-Joe
Actually, the node command is fairly forgiving. It will allow either the address and port separated by a whitespace as in:
node 10.10.10.1 80
or using a colon like:
node 10.10.10.1:80
