SPAMMING THROUGH FLOATING IP
We  noticed we are getting SPAM mails , when we checked it was noticed that the sender IP is our System floating IP of F5.
Required now is to get the real IP relaying the SPAM email
Are you using the BIG-IP as a reverse proxy for your SMTP traffic?
Cheers,
Kees
full proxy
SMTP doesn’t support the option to insert the original client ip.
But you could use the irule in this DC answer to log it to a remote log server https://community.f5.com/t5/technical-forum/logging-smtp-traffic-info-via-hsl-to-remote-log-server/td-p/220880
Cheers,
Kees
Hello Kees,
I am new to irule.
saw this irule from your link. but do not know where to add the SMTP IPS here as they are 3 10.161.18.21-23
Hello,
There is no need to add those SMTP addresses.
Hello Kees,
Thanks for much.
The mail issue is tat we do not know the VS relaying the SPAM ail through. W are just seeing the floating IP as the initiator.
How do i assign this Irule since the Virtual server is not knowm
You have to login to the BIG-IP web Gui, goto local traffic → Virtual servers and look for the virtual server with port 25.
Hello Kess,
I have seen the VS,and need to apply this irule to it
Advice if this irule is okay
when RULE_INIT {
set static::smtp_debug 1
set static::route_domain_id 1
when CLIENT_ACCEPTED {
if {[class match [getfield [IP::client_addr] % 1] equals internal_IP]} {
drop
return
STREAM::expression {@[hH][eE][lL][oO] .*[[:cntrl:]][[:cntrl:]]@@ @[eE][hH][lL][oO] .*[[:cntrl:]][[:cntrl:]]@@ @[.][[:cntrl:]][[:cntrl:]]@@ @354 End data with @@ @250 2.0.0 Ok: queued as @@}
STREAM::enable
set disable_matching 0
when STREAM_MATCHED {
switch -glob [STREAM::match] {
"354 End data with " {
incr disable_matching
STREAM::replace
return
"250 2.0.0 Ok: queued as " {
STREAM::replace
return
default {
set mstring_hex “”
set mstring_hex_trimmed “”
set mstring_ascii “”
set c_initiation_string_hex_trimmed “”
set detected_c_initiation_string “”
binary scan [STREAM::match] H* mstring_hex
set mstring_hex_trimmed [string range $mstring_hex 0 end-4]
set mstring_ascii [binary format H* $mstring_hex_trimmed]
if { $mstring_ascii eq “\.” } {
STREAM::replace
return
if { $disable_matching > 0 } {
STREAM::replace
return
if { ( [string tolower $mstring_ascii] starts_with "helo " ) or ( [string tolower $mstring_ascii] starts_with "ehlo " ) } {
set c_declared_id [string range $mstring_ascii 5 end]
if { $c_declared_id contains “\[” } {
set c_declared_id [ string map [ list \[ “” \] “” ] $c_declared_id ]
set a null
set b null
set c null
set d null
scan $c_declared_id {%d.%d.%d.%d} a b d c
if { !($a == “null”) && !($b == “null”) && !($c == “null”) && !($d == “null”) } {
if { (0 <= $a) && ($a <= 255) &&
(0 <= $b) && ($b <= 255) &&
(0 <= $c) && ($c <= 255) &&
(0 <= $d) && ($d <= 255) } {
if { $static::route_domain_id != 0 } {
append c_declared_id “%” $static::route_domain_id
if { not ( $c_declared_id equals [IP::client_addr] ) } {
drop
return
if { ! ( $c_declared_id contains “\.” ) } {
drop
return
set resolved_addrs [RESOLV::lookup @172.18.240.210%$static::route_domain_id -a $c_declared_id]
set resolved_addrs [RESOLV::lookup @172.18.240.210 -a $c_declared_id]
if { not ( $resolved_addrs equals “” ) } {
set addr_matched 0
foreach resolved_addr $resolved_addrs {
append resolved_addr “%” $static::route_domain_id
if { $resolved_addr equals [IP::client_addr] } {
incr addr_matched
break
if { $addr_matched < 1 } {
drop
return
drop
return
STREAM::replace
return
when SERVER_CONNECTED {
STREAM::expression {@354 End data with @@ @250 2.0.0 Ok: queued as @@}
STREAM::enable
Yes it is. Before applying it to the virtual server you have to attach a stream profile to the virtual server.
