I have a situation where I need to change the gateway of an Edge Gateway client after it has been authenticated and assigned an IP from the lease pool. Currently, the setup is as such with the default route being FW1
EGW Client -- Inet -- FW1 -- F5
Since I can’t move the NAT to FW2 just yet, we are hoping we can alter the gateway after the EGW client is authenticated. I’m unsure how to accomplish this with an iRule as I’m not sure where in the process the client is assigned an IP from the lease pool.
Any help/suggestions are appreciated!
I think this should work. I’m just a bit unclear how APM and the network access tunnel fits into the picture (in terms of packet processing):
when CLIENT_ACCEPTED { if {[class match [IP::client_addr] equals EGW_Lease_list]} { log local0. “[IP::client_addr] matches EGW_Lease_list” nexthop DMZ 192.168.90.10} }
This does not work as the rule fires before the client is authenticated, therefore the client IP addr is their real one, not the lease-assigned one. I’ve searched all over here but I don’t see a way to pull in the APM lease IP. Any suggestions? Is this not possible?
it looks like you could use the “Example: Directing users to different route domains” from the advance APM topics, do you agree?
