Dear Dev Team,
We have the below configuration on LTM.
VIP1: 10.1.1.1:80
Pool Member11: 192.168.1.1:80
Pool Member11: 192.168.1.2:80
LB Method: Round Robin
Persistence: Source Address
VIP2: 10.2.2.2:80
Pool Member21: 192.168.2.1:80
Pool Member22: 192.168.2.2:80
Pool Member23: 192.168.2.3:80
Pool Member24: 192.168.2.4:80
When the client request for URL: www.test.com which is hosted behind VIP1, request will come to “Pool Member11 or Pool Member12” . Then the “Pool Member11 or Pool Member12” will initiate a connection to VIP2.
The problem here we are facing is always “Pool Member21 or Pool Member22” are getting utilized and we do not see any connections to “Pool Member23 or Pool Member24” which is leading to inefficiant distribution of load.
Is it a possible to have persistence based on the “Source IP” and “Source Port” when “Pool Member11 or Pool Member12” initiates connections to VIP2?
Could you pls suggest me an iRule which can overcome the above problem?
Best Regards,
e.g.
[root@ve10:Active] config b virtual bar list
virtual bar {
snat automap
pool foo
destination 172.28.19.252:80
ip protocol 6
rules myrule
[root@ve10:Active] config b pool foo list
pool foo {
members {
200.200.200.101:80 {}
200.200.200.111:80 {}
[root@ve10:Active] config b rule myrule list
rule myrule {
when CLIENT_ACCEPTED {
persist uie [IP::client_addr]:[TCP::client_port]
[root@ve10:Active] config b persist show all
PERSISTENT CONNECTIONS
| Mode universal Value 172.28.69.28:39089
| virtual 172.28.19.252:80 node 200.200.200.101:80 age 8sec
| Mode universal Value 172.28.69.28:39091
| Mode universal Value 172.28.69.28:39093
| Mode universal Value 172.28.69.28:39095
| Mode universal Value 172.28.69.28:39097
| Mode universal Value 172.28.69.28:39088
| virtual 172.28.19.252:80 node 200.200.200.111:80 age 8sec
| Mode universal Value 172.28.69.28:39090
| Mode universal Value 172.28.69.28:39092
| Mode universal Value 172.28.69.28:39094
| Mode universal Value 172.28.69.28:39096
