source_addr persistence timeout based on uri
I have a requirement to set the persistence timeout associated with virtual server based on URI.
In other words, if you browsed /sixty/ the source_addr_60 persistence profile would be applied and if you browsed /twenty/ the source_addr_20 persistence profile would be applied.
Can this be accomplished using an iRule?
You can use the persist command (Click here) to specify how to persist the client, but you can’t actually specify a custom persistence profile:
       Persist based on the requested URI (case-insensitive)
      switch -glob [string tolower [HTTP::uri]] {
         "/twenty*" {
             Persist the client for 20 minutes based on source IP with /32 mask
            persist source_addr 255.255.255.255 1200
         "/sixty*" {
             Persist the client for 60 minutes based on source IP with /32 mask
            persist source_addr 255.255.255.255 3600
         default {
             Take some default action?
You should consider adding a OneConnect profile to the VIP when using a rule like this. (Click here) for details.
Aaron
I appreciate your help Aaron
