some questions on "reject"
1:it seems “'reject” will show u overflow page ,right?
2:even request hit “reject”,it will still execute the subsequent code in irule,right?
1. i got the connection was reset page.
2. yes, i think so.
[root@iris:Active] config  b virtual bar list
virtual bar {
   snat automap
   pool foo
   destination 172.28.17.33:http
   ip protocol tcp
   rules myrule
[root@iris:Active] config  b rule myrule list
rule myrule {
   when CLIENT_ACCEPTED {
        log local0. "before reject command"
        reject
        log local0. "after reject command"
[root@iris:Active] config  tcpdump -nni 0.0 port 80
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on 0.0, link-type EN10MB (Ethernet), capture size 108 bytes
12:35:41.495068 IP 192.168.206.102.50844 > 172.28.17.33.80: S 3555768222:3555768222(0) win 8192
12:35:41.495126 IP 172.28.17.33.80 > 192.168.206.102.50844: S 3902321246:3902321246(0) ack 3555768223 win 3780
12:35:41.495407 IP 192.168.206.102.50844 > 172.28.17.33.80: . ack 1 win 16695
12:35:41.495482 IP 172.28.17.33.80 > 192.168.206.102.50844: R 1:1(0) ack 1 win 3780
12:35:41.496673 IP 192.168.206.102.50845 > 172.28.17.33.80: S 813505315:813505315(0) win 8192
12:35:41.496708 IP 172.28.17.33.80 > 192.168.206.102.50845: S 370932803:370932803(0) ack 813505316 win 3780
12:35:41.497102 IP 192.168.206.102.50845 > 172.28.17.33.80: . ack 1 win 16695
12:35:41.497183 IP 172.28.17.33.80 > 192.168.206.102.50845: R 1:1(0) ack 1 win 3780
12:35:41.497376 IP 192.168.206.102.50845 > 172.28.17.33.80: P 1:369(368) ack 1 win 16695
12:35:41.497393 IP 172.28.17.33.80 > 192.168.206.102.50845: R 1:1(0) ack 369 win 0
10 packets captured
10 packets received by filter
0 packets dropped by kernel
[root@iris:Active] config  tail -f /var/log/ltm
Oct 13 12:35:29 local/tmm notice tmm[4601]: 013e0001:5: Tcpdump starting bcast on :::0 from 127.1.1.1:44469
Oct 13 12:35:41 local/tmm info tmm[4601]: Rule myrule : before reject command
Oct 13 12:35:41 local/tmm info tmm[4601]: Rule myrule : after reject command
Oct 13 12:35:47 local/tmm notice tmm[4601]: 013e0002:5: Tcpdump stopping on 127.1.1.2:1030 from 127.1.1.1:44469
hmmm,so what is displayed in your broswer? overflow page?or nothing ?
Hmmm,I have tried this,when u have configured fallback host in your profile,it will go to fallback host and then fin
if not,it will get rst ,
hmmm,so what is displayed in your broswer? overflow page?or nothing ?the connection was reset is shown in firefox. internet explorer cannot display the webpage is when using ie.
hmm can u try http profile with a fallback host,it will go to fallback host,
hmm can u try http profile with a fallback host,it will go to fallback host,what version are you running? there is a bug in old version i.e. prior 9.3.0.
I run it on 10.2
if reject is in CLIENT_ACCEPTED, connection will be rejected.
[root@iris:Active] config  b version|grep -iA 1 version
BIG-IP Version 10.2.2 930.0
Hotfix HF3 Edition
virtual bar {
   snat automap
   pool foo
   ip protocol tcp
   rules myrule
   profiles {
      myhttp {}
      tcp {}
rule myrule {
        reject
        reject
[root@iris:Active] config  b pool foo|grep -i pool\ member
+-> POOL MEMBER foo/10.10.70.110:http   inactive,down
[root@iris:Active] config  curl -I http://172.28.17.33
curl: (52) Empty reply from server
rule myrule {
        reject
        reject
HTTP/1.0 302 Found
Connection: close
opp, forgot to list myhttp profile.
[root@iris:Active] config  b profile myhttp list
profile http myhttp {
   defaults from http
   fallback "http://www.google.com"
oh,yes,u are right
