SOL7530 Problem: snmpd.conf is synchronized
Snmpd.conf is synchronized at ConfigSync. Are there another workaround?
Comment out the referenced line in your cs.dat file in both systems, or simply change the reference from file to ignore
Comment it out
/usr/libdata/configsync/cs.dat:
save.2340.file = /config/snmp/snmpd.conf
Change the attributes
Keep original setting in a comment for reference
save.2340.ignore = /config/snmp/snmpd.conf
Thanks, but I want to save the snmpd.conf in ucs, and I worry about the cs.dat is overwrited in future upgrade.
Are there another workaround for SOL7530?
SOL7530: Configuring an SNMPv1 trap to use a source IP address other than the management IP address.
