I have a certificate problem where F5 does not include the SAN extension in the generated CSR. See the following doc for details sol13770: The BIG-IP system fails to include the Subject Alternative Name extension while generating a CSR.
The workaround is to use OpenSSL to generate the CSR, see (sol11438). The problem is that I receive the following error for key mismatch when I try to import the certificate signed by CA. Is there away to tell F5 where to look for the private key under /var/tmp/mySSL/www.example.com.key?
01070313:3: Error reading key PEM file /config/filestore/files_d/Common_d/certificate_key_d/:Common:example.com.key_15190_1 for profile /Common/example.com: error:0B080074:x509 certificate routines:X509_check_private_key:key values mismatch
