I am trying to create a HTTP Soap monitor but continally get error messages when creating the monitor like “Value may not contain literal newline characters.”
Below is a capture of the traffic that I need to create the soap Monitor from. Any assitance is appreciated.
POST /f5ping HTTP/1.1
Content-Type: text/xml;charset=UTF-8
SOAPAction: “http://test1.com.au/services/address/wsdl/0/findAddress”
Authorization: Basic dTU1NDAzMjpudWxs
User-Agent: Jakarta Commons-HttpClient/3.0.1
Host: 192.168.1.1:9001
Content-Length: 209
Instead of putting the request in literally, you can replace the line breaks with \r\n which is the escape sequence for a carriage return and line feed.
Aaron
I have added the following into the Monitor but I still get " ! Value may not contain literal newline characters. "
POST /f5ping HTTP/1.1\r\n
Content-Type: text/xml;charset=UTF-8\r\n
SOAPAction: “http://test1.com.au/services/address/wsdl/0/findAddress”\r\n
Authorization: Basic dTU1NDAzMjpudWxs\r\n
Host: 192.168.1.1:9001\r\n
Content-Length: 209\r\n
\r\n
\r\n
\r\n
\r\n
The entire entry needs to be on one line with no actual line breaks.
I don’t think you need any of the \r\n’s in or after the payload. You need to update the content length based on the number of characters in the payload.
Aaron
