SOAP Monitor
I am trying configuring the health monitor for SOAP service (HTTP POST)? Response is nested & As per F5 KB myF5 nested response is not supported. F5 recommendation is “you modify server responses to send required SOAP monitor strings within the top level of the response (non-nested). Alternatively, you can use an HTTP monitor with an iRule for the pool member”.
or can someone suggest how to make use of http monitor with i-rule to do healthcheck of SOAP service? & how the i rule will look like?
Normally HTTP/HTTPs monitor support varius of web application e.g. HTML, REST, SOAP.
The send string in monitor profile just put the full SOAP REQUEST in XML format.
Hi NUT2889,
Thanks for your response.
Can you please send me an example how to put SOAP request in XML format ?
