Hello All, I want to configure the F5 LTM SNMPv3 with Solarwinds can any one provide me a step by step guide to configure SNMPv3 of F5 for Solarwinds.
Hello humi,
I think you must set here: System ›› SNMP : Agent : Configuration
the IP for Solarwinds,
and then to set here: System ›› SNMP : Agent : Access (v3)
the other stuff regarding the settings in Solarwinds plus
OID = .1.3.6.1
I hope this will help.
Regards,
Preslav
can you provide the snapshot of overall configuration, it will be helpful for me.
System > SNMP > Agent > Configuration Add your SolarWinds IP as the host and click add. This will whitelist that SNMP server to probe the F5.
System > SNMP > Agent > Access (v3) Create > Username an Auth/Priv information. OID: .1
Network > Self IPs > Your incoming interface for SNMP > Verify “Allow Default” is allowed on the port lock down, otherwise add SNMP service to the port list with “Allow Custom”
From the link myF5
OIDNot ApplicableSpecifies the object identifier for this SNMPv3 access record. This provides access restriction to a specific OID, or OID tree. Setting the OID to .1 allows access to all OIDs on the device.
