Our SNMP is set without a source so I assume the default mgmt interface is used , but just in case I did one tcpdump with no interface mentioned just the port , same result.
The last trap was confirmed working on a different BIG-IP system by one of my colleagues.
Am I doing something wrong ?
Did I choose some bad trap codes ? Or am I not using proper tcpdump options ?
tried it , this time i get a zero across the board :
0 packets captured
0 packets received by filter
0 packets dropped by kernel
Still , the system no longer prompted me that there is no ip address as it did when i mentioned -eth0 (although the official F5 guide says that you can’t use eth0:mgmt and eth0 is the mgmt interface in the tcpdump option)
