SNMP OID for tmm cpu utilization
Is there a way to monitor the CPU usage per TMM. OID .1.3.6.1.4.1.3375.2.1.8.2.3.1.28 ,29 ,30 doesn’t provide any data.
snmpwalk -c public 127.0.0.1 1.3.6.1.4.1.3375.2.1.8.2.3.1.28 F5-BIGIP-SYSTEM-MIB::sysTmmStatTmTotalCycles.“0.0” = Counter64: 0 F5-BIGIP-SYSTEM-MIB::sysTmmStatTmTotalCycles.“0.1” = Counter64: 0 F5-BIGIP-SYSTEM-MIB::sysTmmStatTmTotalCycles.“0.2” = Counter64: 0 F5-BIGIP-SYSTEM-MIB::sysTmmStatTmTotalCycles.“0.3” = Counter64: 0
snmpwalk -c public 127.0.0.1 1.3.6.1.4.1.3375.2.1.8.2.3.1.29
F5-BIGIP-SYSTEM-MIB::sysTmmStatTmIdleCycles.“0.0” = Counter64: 0 F5-BIGIP-SYSTEM-MIB::sysTmmStatTmIdleCycles.“0.1” = Counter64: 0 F5-BIGIP-SYSTEM-MIB::sysTmmStatTmIdleCycles.“0.2” = Counter64: 0 F5-BIGIP-SYSTEM-MIB::sysTmmStatTmIdleCycles.“0.3” = Counter64: 0
snmpwalk -c public 127.0.0.1 1.3.6.1.4.1.3375.2.1.8.2.3.1.30 F5-BIGIP-SYSTEM-MIB::sysTmmStatTmSleepCycles.“0.0” = Counter64: 0 F5-BIGIP-SYSTEM-MIB::sysTmmStatTmSleepCycles.“0.1” = Counter64: 0 F5-BIGIP-SYSTEM-MIB::sysTmmStatTmSleepCycles.“0.2” = Counter64: 0 F5-BIGIP-SYSTEM-MIB::sysTmmStatTmSleepCycles.“0.3” = Counter64: 0
This is unimplemented on my boxes too.
You would need to walk the processes to find the tmm processes, then use F5-BIGIP-SYSTEM-MIB::sysProcPidStatCpuUsageRecent. to get current CPU
is it a difference to the generally cpu usage?
cpu - usage: the easiest way is to use the Host Mib. if you walk from here: .1.3.6.1.2.1.25.3.3.1, you get the cpu usage for every cpu.
for tmm, I have the same stuff like you, but I dont use it. Its all based on the TMM id. With this id you can combine all the informations you need. PID, CPU index, TMM index, …
TMM id: .1.3.6.1.4.1.3375.2.1.8.2.3.1.1
So in your example:
TMM 0.0 --> 0% cpu
TMM 0.1 --> 0% cpu
TMM 0.2 --> 0% cpu
TMM 0.3 --> 0% cpu
is sysTmmStatTmUsageRatio* OID usable?
[root@B3600-R70-S26:Active:Standalone] config  snmpwalk -v 2c -c public localhost f5 |grep sysTmmStatTmUsageRatio
F5-BIGIP-SYSTEM-MIB::sysTmmStatTmUsageRatio5s."0.0" = Counter64: 1
F5-BIGIP-SYSTEM-MIB::sysTmmStatTmUsageRatio5s."0.1" = Counter64: 1
F5-BIGIP-SYSTEM-MIB::sysTmmStatTmUsageRatio1m."0.0" = Counter64: 1
F5-BIGIP-SYSTEM-MIB::sysTmmStatTmUsageRatio1m."0.1" = Counter64: 1
F5-BIGIP-SYSTEM-MIB::sysTmmStatTmUsageRatio5m."0.0" = Counter64: 1
F5-BIGIP-SYSTEM-MIB::sysTmmStatTmUsageRatio5m."0.1" = Counter64: 1
by the way, you know sysTmmStatTm*Cycles is deprecated, don’t you?
sysTmmStatTmTotalCycles OBJECT-TYPE
        SYNTAX Counter64
        MAX-ACCESS read-only
        STATUS   deprecated
        DESCRIPTION
                "Deprecated! Please use the provided tmm usage ratios.
                Traffic management CPU usage. The total cycles spent in traffic management."
        ::= { sysTmmStatEntry 28 }
oh, nice to know, that it is deprecated.
I don’t use it, so I didn’t know. For me it is only interesting to know total cpu usage. I don’t find a dedicated way to compare to value with a performance value in the gui. Perhaps you can use the statistics view of all your virtual server.
If I look on my device, there is only 1 VS with 1% cpu, all other VS are running with 0% cpu :slight_smile: So, I would say sysTmmStatTmUsageRatio* is usable.
Thanks Nitass for letting me know that sysTmmStatTm*Cycle is deprecated so can you please let me know the formula to calculate TMM CPU using tmm usage ratios. IS there any formula for it?
as far as i know, it is derived from tm statistics (tmctl output).
