Hello,
I’ve configured a SNMP monitor using the snmp_dca parent monitor.
The SNMP traffic is well working between our LTM and the node on which the monitor is attached.
( the goal is attached this SNMP monitor to a node so that when the node is running high cpu/mem , it’s deactivated by the F5 LTM and all application pool using that node will be rebalanced to remaining health nodes)
When I check the logs from the snmpdca.log , I well see that my current CPU is 99% but the node stay up from LB point of view.
Node Name: /DCS-LB-Partition/FLE-SP02
Node Address: ::ffff:X.X.X.X
SNMP version: v1, community = <sensitive data redacted>, port: 161
Monitor: snmp_dca
Agent Type: WIN2000
User OIDs:
Mem OIDs:
.1.3.6.1.2.1.25.2.2.0 - 8387532.000000
Cpu OIDs:
.1.3.6.1.2.1.25.3.3.1.2.7 - 99.000000
Disk OIDs:
.1.3.6.1.2.1.25.2.3.1.4.1 - 4096.000000
.1.3.6.1.2.1.25.2.3.1.6.1 - 10067042.000000
.1.3.6.1.2.1.25.2.3.1.5.1 - 20813567.000000
i = 0, util = 0.000000, threshold=70.000000, coeff=1.000000
i = 1, util = 50.000000, threshold=50.000000, coeff=1.000000
i = 2, util = 48.367692, threshold=90.000000, coeff=2.000000
Main:Weight =19 (weight1 = 0.000000, weight2 = 19.417098)
Can someone explain me why the node on which the monitor is attached, does not go down ?
The CPU is constant at 99% for a while but this does not seems to make the node down on LTM .
Thanks in advance for your help.
Regards
Frédéric
