Ive got 3 different Hardware Setups (Bigip i5600, i2600 and i7800).
1. What are the correct OIDs if i want to check the Hardware:
- CPU Usage (not every core / just one single result)
- Memory Usage (for the whole hardware system if possible)
- Disk Usage (for the whole hardware system if possible)
2. What are the correct OIDs if i want to check the VCMP Guests on the i7800:
- CPU Usage
- Memory Usage
- Disk Usage
There are a lot on the MIB Files and Results but which are the OIDs you want use in this case?
