SNAT PBR Irule
Hi, I am trying to replicate Cisco PBR configuration in F5 LTM using an irule, I have a condition, if Local_Client = 192.168.11.10 is trying to access Remote_Server = 192.168.12.10, I want to translate the source to SNAT_IP = 192.168.12.10.
I have to put the irule to a forwarding virtual server that forwards traffic for all the inside clients to outside…and vice versa…I just want to put the conditional SNAT for the Local_Client.
when CLIENT_ACCEPTED { if { [IP::addr [IP::client_addr] equals 192.168.11.10/32] } { if { [IP::addr [IP::remote_addr] equals 192.168.13.10/32 ] } { snat 192.168.12.10 } } }
I have tried it but it does not seem to work, need your experts’ suggestion.
I don’t think client_accepted will work in this case since you are using a Forwarding(IP) VIP and the first packet will be sent to the destination before the three way handshake is complete. What version are you running? If you are running 11.5+ you can create you forwarding(IP) VIP with source and destination and just apply your SNAT to that VIP.
“>https://devcentral.f5.com/wiki/iRules.CLIENT_ACCEPTED.ashx” target=“_blank”>">https://devcentral.f5.com/wiki/iRules.CLIENT_ACCEPTED.ashx
What does ip any profile does…I want to permit both TCP and UDP from source to destination…but when I select all protocol…this profile (ipother) is getting applied…which according to help says any traffic other than tcp & udp?
it seems in case of fastL4 CLIENT_ACCEPTED is triggered before finishing 3-ways handshake.
e.g.
snat 123.123.123.123 is dummy one (invalid). so, 3-ways handshake will never be established.
configuration
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual norf
ltm virtual norf {
    destination 172.28.24.10:80
    ip-protocol tcp
    mask 255.255.255.255
    pool foo
    profiles {
        fastL4 { }
    rules {
        qux
    source 0.0.0.0/0
    source-address-translation {
        type automap
    vs-index 7
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm pool foo
ltm pool foo {
    members {
        200.200.200.101:80 {
            address 200.200.200.101
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm rule qux
ltm rule qux {
  log local0. ""
  if { [IP::addr [IP::client_addr] equals 172.28.24.1/32] } {
when SERVER_CONNECTED {
  log local0. ""
 trace
[root@ve11a:Active:In Sync] config  tcpdump -nni 0.0 -s0 port 80
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on 0.0, link-type EN10MB (Ethernet), capture size 65535 bytes
11:54:12.913262 IP 172.28.24.1.56738 > 172.28.24.10.80: S 3457045251:3457045251(0) win 5840  in slot1/tmm0 lis=
11:54:12.913445 IP 123.123.123.123.56738 > 200.200.200.101.80: S 3457045251:3457045251(0) win 5840  out slot1/tmm0 lis=/Common/norf
 /var/log/ltm
[root@ve11a:Active:In Sync] config  cat /var/log/ltm
Dec  9 11:54:10 ve11a notice tmm1[14890]: 013e0001:5: Tcpdump starting bcast on 127.1.1.3:2 from 127.1.1.1:35239
Dec  9 11:54:10 ve11a notice tmm[14890]: 013e0001:5: Tcpdump starting bcast on 127.1.1.2:2 from 127.1.1.1:35239
Dec  9 11:54:12 ve11a info tmm[14890]: Rule /Common/qux :
Dec  9 11:54:18 ve11a notice tmm1[14890]: 013e0002:5: Tcpdump stopping on 127.1.1.3:2 from 127.1.1.1:35239
Dec  9 11:54:18 ve11a notice tmm[14890]: 013e0002:5: Tcpdump stopping on 127.1.1.2:2 from 127.1.1.1:35239
