I have an iRule applied to a virtual server that will allow a server behind the F5 to connect to a VIP. When I do HTTP it works fine. HTTPS doesn’t work. All I see are the SYN’s and never see any ACK’s. Here is how everything is setup.
client(10.63.136.14) ---> VIP(10.63.27.124) ----> server(10.63.136.11)
when CLIENT_ACCEPTED { if { [IP::addr [IP::client_addr] equals 10.63.136.14] and [IP::addr [IP::local_addr clientside] equals 10.63.27.124]} { snat automap } }
can you post the virtual server configuration?
tmsh list ltm virtual (name)
ltm virtual DIGITALMEDIAHUBTEST-PW.WWWINC.COM _HTTP_443_vs { destination 10.63.27.124:https ip-protocol tcp mask 255.255.255.255 profiles { WWWINC.COM _SSL { context clientside } http { } tcp { } } rules { DIGITALMEDIAHUBTEST-PW.WWWINC.COM _SNAT DIGITALMEDIAHUBTEST-PW.WWWINC.COM _pw_redirect } source 0.0.0.0/0 vlans { DMZ-Peoplesoft External } vlans-enabled vs-index 63 }
ltm virtual DIGITALMEDIAHUBTEST-PW.WWWINC.COM_HTTP_443_vs {
ip-protocol tcp
profiles {
WWWINC.COM_SSL {
context clientside
http { }
tcp { }
rules {
DIGITALMEDIAHUBTEST-PW.WWWINC.COM_SNAT
DIGITALMEDIAHUBTEST-PW.WWWINC.COM_pw_redirect
source 0.0.0.0/0
vlans {
DMZ-Peoplesoft
External
vlans-enabled
vs-index 63
Domai
June 5, 2014, 4:46pm
5
Just for the heck of it can you remove the irule and assign SNAT to your https VS and see if that works. Also you are sending the traffic to the members listening on port 80 correct since you are not using server side ssl…you are terminating the SSL at LTM itself?
Still didn’t work. Here is the config.
ip-protocol tcp
profiles {
WWWINC.COM_SSL {
context clientside
http { }
tcp { }
rules {
source 0.0.0.0/0
source-address-translation {
type automap
vlans {
DMZ-Peoplesoft
External
vlans-enabled
vs-index 63
I setup the irule to log and I don’t even see the request via HTTPS being logged. This is what I see with HTTP.
Jun 5 14:36:00 ROCANNF5 local0 info tmm[13141]: Rule /Common/DIGITALMEDIAHUBTEST-PW.WWWINC.COM_SNAT : 10.63.136.14, 10.63.27.124
I performed a packet capture and the HTTP traffic gets SNAT’ed to the self ip of the F5. The HTTPS traffic never looks like it gets NATed
Since it is HTTPS is the irule able to inspect the IP’s since its encrypted?
I figured it out. It helps when you enable the VS on the right VLAN.
I believe its just the data packet that will be encrypted. You should still be able to see the ips at the layer 4 level that would not be encrypted.
Oh did you assign the wrong destination ip for the VS?
No just didn’t enable the VS on the correct VLAN.
Is the HTTPS traffic hitting the VS? I.E., do you see the HTTPS SYN packets actually arriving at the BIG-IP? Can there be a firewall device in between that is simply blocking port 443 to the VS?
