I am trying to setup non-HTTP vServer. End server needs to see client source IP. After disabling SNAT ( SNAT=NONE), I am getting source IP as Self IP. End server GW is pointing to Self-IP. Why source IP is Self IP when SNAT is set to none.
Where do you see a self ip as a source? If SNAT is not set the only traffic sourcing from self ip should be monitors testing availability of the nodes (backend servers).
This was my vserver config ( created http vserver to test) - (Active)(tmos) list ltm virtual mo_test_80-vs ltm virtual mo_test_80-vs { destination 10.4x.x.2:http ip-protocol tcp mask 255.255.255.255 persist { motTest { default yes } } pool mo_test-80 profiles { fasthttp { } } snatpool Default-SNAT }
Changed to ltm virtual mo_test_80-vs { destination 10.x.x2:http ip-protocol tcp mask 255.255.255.255 persist { motTest { default yes } } pool mo_test-80 profiles { fasthttp { } } }
I am getting source IP as per default-SNAT. I have changed monitor interval to 1000 second so it is not monitor traffic.
Ok. In this case I would use tcpdump to sniff through the traffic and see what is going on. Regarding the configuration you posted. It looks somewhat strange as I would expect snatpool definition within source-address-translation.
What version are you running?
It is BIG-IP - 10.2.4
It’s tough to chase problems with old code - 10.2.4 is from 2012… What’s the issue with upgrading? unsupported hardware? or environment restrictions?
Have you tried deleting all current connections? to/from the VIP in question and testing again? If not, that may be it.
Hi ADC,
I think you probably have to create a NAT, can you check in:
- Local Traffic ›› Address Translation : NAT List ›› New NAT…
And told me if you set up a NAT for specific Origin Address.
How you constate that snat don’t work? so if my first suposition is not right can you validate that Request that is comming to the node with self IP is not a monitoring request?
regards
Is there any SNAT (not SNAT POOL) with source IP 0.0.0.0/0 and with automap?
If there is such object, it will enable automap even if the virtual server is not configured with SNAT POOL!
