Snat Issue
Hi Guys,
I have an issue in translating the Client Source address to internal node IP Subnet in the F5. Could you please provide some clear idea on how snat works.
Regards
Seems like you made a re-post, but I’ll repeat my answer here as well:
There are multiple ways of translating IP’s. If all you want is to translate incoming client source IP’s on a particular virtual server I’d recommend using a SNAT pool.
To use a SNAT pool on a virtual server:
Go to the virtual server config page. Change Source Address Translation from “None” to automap, or a custom SNAT Pool that you’ve create yourself. Note that if you create a SNAT pool yourself it should contain at least one IP in the subnet facing the member servers.
/Patrik
