SNAT iRule
I am trying to write a SNAT rule that will use a data group to map the client address to a specific SNAT in version 10.2.3. Due to the protocol, we need this functionality to allow traceability in our environment. The iRule never returns a value from the data group. I have tried many formats for the string group, but no luck in matching. Am I not formating the data group correctly or am I having trouble comparing the string to the address? I’ve tried many different ways to format the class match line as well.
class snat_map {
“\“10.100.61.150\” := { \“10.146.1.7\” }”
“\“10.100.61.150\” { \“10.146.1.3\” }”
“10.100.61.150 := { \“10.146.1.4\” }”
“10.100.61.150 { \“10.146.1.6\”}”
“10.100.61.150 { 10.146.1.5 }”
“10.100.61.150:=10.146.1.3”
rule snat_rule {
when CLIENT_ACCEPTED {
TCP::collect 8
set srcip [IP::client_addr]
log local0. “Entering iRule snat_rule $srcip”
set snat_address [class match -value “$srcip” equals snat_map]
log local0. “snat_address is $snat_address”
if { “$snat_address” ne “” } {
log local0. “Using address $snat_address”
snat $snat_address
Use default SNAT pool if not found
Feb 15 07:02:55 local/tmm1 info tmm1[2858]: Rule slp_snap_rule : Entering iRule slp_snat_rule 10.100.61.150
Feb 15 07:02:55 local/tmm1 info tmm1[2858]: Rule slp_snap_rule : snat_address is
e.g.
[root@ve10:Active] config  b class snat_map list
class snat_map {
   "10.100.61.150" { "10.146.1.7" }
[root@ve10:Active] config  b rule myrule list
rule myrule {
   when RULE_INIT {
   set srcip "10.100.61.150"
   log local0. "\[class match -value $srcip equals snat_map\] [class match -value $srcip equals snat_map]"
[root@ve10:Active] config  cat /var/log/ltm
Feb 16 09:39:50 local/tmm info tmm[4909]: Rule myrule : [class match -value 10.100.61.150 equals snat_map] 10.146.1.7
I receive the following error when I use this format.
01070151:3: Rule [snat_rule] error: line 6: [wrong args] [class match - value $srcip equals snat_map]
If I put quotes around the srcip variable it will compile, but it won’t match anything in the class.
Is the log command all on one line? It should be.
Yes, it is one line.
OK, can you post your exact code?
Below if the latest.
TCP::collect 8
set snat_address [class match -value “[IP::client_addr]” equals snat_map]
snat $snat_address
class snat_map {
“\“10.100.61.150\” { \“10.146.1.7\” }”
The rule code looks good to me. It saves OK on my v11.3 VE.
Did you miss the closing } for the Class configuration?
Interesting that the error references line 6, has the rule changed since you posted the error message?
If I use the string in data group, the snat is executed in v11.x???
Tks
Luis
