SNat iRule based on destination address
Hi All,
I would like to create snat iRule based on the destination IP address. I have VS with 3 pool members. If request hits first 2 pool members then do not SNAT & If destination hits 3rd pool member then SNAT is required.
Could any one please help me to script an iRule for above requirement.
Regards, Mahantesh
try this,
when LB_SELECTED {
  if { not [IP::addr [LB::server addr] equals 10.0.0.1] } {
    snat none
Thanks arpdays for the reply. So above iRule has been written assuming that 10.0.0.1 is the 3rd pool member ? Correct me If I am wrong.. I will check on this & let you know.
Regards, Mahantesh
Yes, also assumes SNAT is configured on VS
cheers
@arpdays,
whether below iRule will work without SNAT on VS ?
when LB_SELECTED { if { not [IP::addr [LB::server addr] equals 10.0.0.1] } { snat none } else { snatpool xyz.com } }
should do, although this may be simpler,
when LB_SELECTED {
  if { [IP::addr [LB::server addr] equals 10.0.0.1] } {
    snatpool xyz.com
OK Thanks arpydays for the response. I will check on this & will update you.
