Hi, one of our application is marked down and with a minute it is marked again as up. During that time i m observing close wiats connection to F5 IP in app servers. By looking at F5 config i could see snat is set NONE. is this the cause ? if we set to automap will it resolve the issue., if so please guide me.
Hi Chitrarasu,
I doubt that it is the SNAT. It looks like what you describing is the monitors going up/down which do not use SNATs. You should focus between the the monitor parameters and server itself.
I hope this helps,
Can you list the Virtual and monitor configuration. Ping the server and see if its timing out intermittently.
