I am trying to create a VS using Ansible playbook. It is able to create the virtual server but not able to set SNAT setting that i wanted (Automap), getting the following error
fatal: [xxx.com]: FAILED! => {“changed”: false, “failed”: true, “msg”: “received exception: Error on setting snat : Method not found: ‘LocalLB.VirtualServer.LocalLB.VirtualServerPort.get_source_address_translation_type’”}
Version details:
- Ansible: 2.3.0.0
- python: 2.7.5
- BigIP: 11.12.1
this is how my playbook looks
name: Create virtual server
bigip_virtual_server:
server: xxx.com
user: admin
password: MYPASS
state: present
destination: DEST_IP
port: 80
pool: POOL_NAME
all_profiles:
- tcp
- http
snat: Automap
validate_certs: no
Any support on this would be really appreciated. Thanks!
Hello,
You have to use “source-address-translation” instead snat and set it to “type automap”. It will work.
I advise you for the future to test your parameter trough tmsh:
tmsh modify ltm virtual vs-name source-address-translation { type automap }
Regards,
can you try following the procedure in this url: F5 Cloud Docs
I noticed that on the reference url, snat is defined higher up the list compare to yours, its in the bottom.
can you try modifying your playbook and somewhat copy what is in the reference url? share any errors when you run the playbook after the change.
when running your playbook, since you are getting an error, can you enable verbose logging and share the output? see this url:
hopefully, this will give more verbose output on the errors received.
see also F5 Cloud Docs
I had interchanged the modules/arguments to the way it is showed in the reference url, but had no luck, i got the same error
password: MY_PASS
pool: POOL_NAME
port: 80
server: xxx.com
snat: Automap
user: admin
all_profiles:
- tcp
- http
validate_certs: no
error
fatal: [xxx.com]: FAILED! => {"changed": false, "failed": true, "msg": "received exception: Error on updating Virtual Server : Error on setting snat : Method not found: 'LocalLB.VirtualServer.LocalLB.VirtualServerPort.get_source_address_translation_type'"}
I had the same job run it in verbose mode and this is the output i got
TASK [Create virtual server] *********************************************************************************************************************
task path: /etc/ansible/f5-virt.yml:6
Using module file /usr/lib/python2.7/site-packages/ansible/modules/network/f5/bigip_virtual_server.py
ESTABLISH LOCAL CONNECTION FOR USER: root
EXEC /bin/sh -c 'echo ~ && sleep 0'
EXEC /bin/sh -c '( umask 77 && mkdir -p "` echo /root/.ansible/tmp/ansible-tmp-1525440236.15-140334385587090 `" && echo ansible-tmp-1525440236.15-140334385587090="` echo /root/.ansible/tmp/ansible-tmp-1525440236.15-140334385587090 `" ) && sleep 0'
PUT /tmp/tmpfOasSB TO /root/.ansible/tmp/ansible-tmp-1525440236.15-140334385587090/bigip_virtual_server.py
EXEC /bin/sh -c 'chmod u+x /root/.ansible/tmp/ansible-tmp-1525440236.15-140334385587090/ /root/.ansible/tmp/ansible-tmp-1525440236.15-140334385587090/bigip_virtual_server.py && sleep 0'
EXEC /bin/sh -c '/usr/bin/python /root/.ansible/tmp/ansible-tmp-1525440236.15-140334385587090/bigip_virtual_server.py; rm -rf "/root/.ansible/tmp/ansible-tmp-1525440236.15-140334385587090/" > /dev/null 2>&1 && sleep 0'
"changed": false,
"failed": true,
"invocation": {
"module_args": {
"all_policies": null,
"all_profiles": [
"tcp",
"http"
"all_rules": null,
"default_persistence_profile": null,
"description": null,
"destination": "DEST_IP",
"enabled_vlans": null,
"fallback_persistence_profile": null,
"name": "VS_NAME",
"partition": "Common",
"password": "VALUE_SPECIFIED_IN_NO_LOG_PARAMETER",
"pool": "POOL_NAME",
"port": "80",
"route_advertisement_state": null,
"server": "xxx.com",
"server_port": 443,
"snat": "Automap",
"state": "present",
"user": "admin",
"validate_certs": false
Thanks for all your time to support this!
@anonymous007
The version of BIG-IP you’re using is to old. In other words “Plan your upgrade path”.
11.12.1 is not an actual version, so I assume you meant 11.2.1. In that case, this method (get_source_address_translation_type) was not introduced until 11.3.0.
So…basically…you’re out of luck.
You can use the bigip_command module in CLI mode for BIG-IP versions earlier than 12.x. However, the real solution as I said earlier, is to plan your upgrade.
