SNAT Configuration on F5
We have 2 servers in DMZ which are the pool members of the F5 VIP. These servers need internet access and servers default gateway is pointing to the F5 self IP. Can we configure the SNAT to allow these servers map to a public IP to access Internet or the rules to be cofigured on the Firewall or is there any other solution to allow Internet access to these dmz servers.
Rather than pointing your DMZ servers to the F5’s self IP, it may be better to stand up a forwarding virtual server and apply an appropriate SNAT to that virtual server. More details on the forwarding virtual server:
The way I normally do it is to point the DMZ servers to the default gateways of your DMZ network. Setup rules in your firewall to allow outbound Internet access for the servers, but block inbound access to the servers. Create another rule to allow HTTP/HTTPS services to the VIP on the F5 for the Pool of servers. SNAT only applies to inbound connections.
As Cory suggested, I’ve traditionally used Forwarding VSs to accomplish what you’re looking for.. Use SNAT, or you can let your firewall handle the translation.. Just remember, either way you have to make sure any devices in front of the LTM knows how to route back to the source address of the connection.. Read through the referenced doc, it’s pretty good.
Be careful with what Vincent is recommending above - it may work in some cases, but can break things in some configurations.. For example - if you have any In-Line traffic you can end up with asymmetric routing and break connections..
Thank you all for the Answers.
1) Can the below SNAT works without chaning any configuration on the servers gateway and without configuring Forwarding Virtual servers.
ltm snat /Common/test_snat { origins { 10.10.10.1/32 { } 10.10.10.2/32 { } } translation /Common/ }
2) As the default gateway of servers is F5 self IP the traffic is not hitting the firewall. I dont think we can add rules on the firewall to allow access to Internet. Let me know if I am wrong.
The SNAt Configuration is
As long as you have defined a valid translation address (can’t tell from your configs, probably sanitized) in your SNAT configuration and all the supporting routing in your network is there to accommodate that address, then this should work.
@Bkanna, even if the F5 is the DG, as long as the FW is in line with all the communication you could still translate the address through it if you wanted to..
