Hello all we have an F5 LTM with different router domains configured. In a RD%3 we have a pool with private IP. This pool is reachable from outside using a VS located in RD%5. This is working properly. From outside customers uses VS public IP in RD%5 and they reach POOL devices on RD%3. What is not working is the outbound traffic. When POOL devices start connections. We configured an SNAT POOL with an public IP%5 (from RD%5). Is there something in particular we have to do for configuring SNAT between different RDs? Basically we want to use a IP from RD%5 for traffic generated form RD%3. Thanks
do you also have virtual server which will match server-initiated traffic? sol9038: The order of precedence for local traffic object listeners 404 Page not found | BIG-IP Documentation anyway, would it be easier to remove snat list and create virtual server for server-initiated traffic (e.g. 0.0.0.0%3:0/0 with 222.30.41.13%5 as snatpool member)? can you try?
