SNAT automap
As in automap client ip will change to self-ip my client asking to see the actual client ip on to the server ? what I will do .. with the same setting…
You can add an “X-Forwarded-For” header. That way you can continue to use SNAT auto-map. XFF header adds the clients original IP address to the packets going to the back end server.
HERE and HERE are a couple resources that should get you on your way!
Hope that helps! If it does please up-vote and select this answer, it’d be greatly appreciated!
-Dylan
X-Forwarded-For can be added in the HTTP profile. The option has to be “enabled” -The type of XFF also depends on the application. There are a few versions of XFF.
In order to answer, we’ll need the application or the Server Operating system version.
