I understand how autonat works but I cant seem to find this answer. If you are not using floating ips and and have multiple public ips assigned to egress vlans, how does the map work.
What I mean by that is it possible that there will be some randomness in the address used to automap. I am thinking that this is a wrong design choice in cases where your application source ip needs to be a constant. In other words I cant have random source ips coming back to clients as I am in a hosted services environment.
Can anyone give some logic here as to how this would work with the scenario I gave above and if it makes sense to use automap where I need the src to be same for clients every time. Also if I add self-ips, my understanding is that it will also use the new ones as that is the concept of automap and why you have endless ports for nat to use…
