Hi
i have only one SNAT automap with 2 class B networks. is it possible to splitt this into class A networks?
is “address list” network only a filter or does it describe a real network?
Tim
Hi
Tim
Hi Tim,
I’m not quite sure what you’re asking, the address list for a SNAT controls which origin addresses get their source IP’s changed to the translation address (automap or not) when they originate a connection to/through the LTM. So you can define whatever origin addresses you want in that field.
Denny
does “network” mean “a real network/subnet”
(including network address/braodcast address) or
does it mean a simple “filtering mask”
(everything fits in this mask will be done)
Tim
Ah, I see…it’s the real network definition.
Denny
