Hello,
I have in ltm a smtp check and the pool with the check is down. With tcpdump can´t see pakets to the nodes and in the debug log is whistled “error: couldn’t open socket: host is unreachable”
Why can´tt I see any packages with tcpdump?
When i use a normal TCP check with port 25 is the pool up
Since the host is unreachable you could have an ARP issue. Meaning, your LTM may not be able to resolve a MAC address for the node you are testing and therefore you are not ever sending a SYN packet to even open the connection.
Why it goes with a normal TCP check on port 25?
can you see packets with tcpdump with your TCP monitor since you say it succeeds?
can you also post the pool and monitors configuration?
tmsh list ltm pool (name)
tmsh list ltm monitor tcp (name)
tmsh list ltm monitor smtp (name)
ltm pool SMTP-TEST { members { TEST1:smtp { address 1.1.1.1 session monitor-enabled state down } TEST2:smtp { address 1.1.1.2 session monitor-enabled state down } } monitor SMTP-TEST partition Common
ltm monitor smtp SMTP-TEST { debug no defaults-from /Common/smtp description “SMTP TEST” destination *:smtp interval 5 partition Common time-until-up 0 timeout 16
ltm monitor tcp TCP25 { adaptive disabled defaults-from /Common/tcp destination *:smtp interval 5 ip-dscp 0 partition Common time-until-up 0 timeout 16
is this relevant?
sol16631: The SMTP monitor may fail to connect and then incorrectly mark down an available pool member
