Can F5 do TCP splitting for SMPP service by iRule?? I mean, in SMPP serivce, one TCP session will include multiple “sessions”, and F5 can distribute those “sessions” to different servers in one pool?? If so, could you please provide a iRule example for me? Thanks very much!!!
Yes, it’s possible, but you will need to build an SMPP message parser. Basically, the idea is to issue LB::detach command after the end of each message transmission - which will force a new load-balancing decision to a different server in the pool for the subsequent message. The rough pseudocode idea is something like this:
when CLIENT_ACCEPTED {
TCP::collect
when CLIENT_DATA {
determine that beginning and end of the message was received
if end of the message was received {
LB::detach
TCP::release
TCP::collect
Thanks very much for your reply!
