Smae VIP with SSL for multiple application, URL based forwarding
Hello mates, I need help on below scenario working on https. /
example :- if url  https://hello.abc.com  will be go to Pool :- hello.abc.com
       if url https://hi.abc.com will go to Pool :- hi.abc.com
          where VIP is same with https port for https://hello.abc.com & https://hi.abc.com
You can choose LTM policies or irules to have several fqdn on the same Virtual Server. If you are using SSL, you need to provision a valid SSL certificate. A SAN certificate or a wildcard is required.
If you choose using the irule, you can try the following one :
        switch -glob [string tolower [HTTP::host]] {
            "hello.abc.com*" {
                pool poolname1
            "hi.abc.com*" {
                pool poolname2
You also need to assign a oneconnect profile to avoid Load Balancing decision issues.
Create a string datagroup named hostpools like the following:
www.abc.com := www.abc.com
            set hostpool [class match -value [string tolower [HTTP::host]] equals hostpools]
            if { $hostpool ne "" } {
                            pool $hostpool
                            discard
                            pool $hostpool
                            discard
HI Ekaleido,
Not able to create irule based on your suggestion
can you help me for mapping example :- if url https://hello.abc.com will be go to Pool :- hello.abc.com
HI Ekaleido,
Hi Benjamin ,
Thanks it’s working with HTTP, but not with HTTPS.
My iRule does exactly what you’re asking for, it just uses a data group to validate that the URL is valid and should be delivered, then it delivers it to a pool sharing the name of the host.
