Slowness experienced after failover.
We currently have 2 VCMP guests in the environment configured as an HA pair. When a failover occurs to the standby, the network experiences extreme slowness after an hour or so. Has anyone else had this experience and if so what was the root cause. just a brief synopsis will do as I really just need a direction to head in for troubleshooting. this is for version 11.5.3.
Some things that I would check - is the traffic pathway same for both the devices in the pair ? If there is difference in traffic path, can you make sure that the speed/duplex/mtu matches between the 2 paths ? Can you also check the traceroute from client for both the devices ? Any errors seen in the devices ?
