Slow with f5 but ok otherwise
We keep getting these issues with customers complaining about some app or website always slow from f5 but works fine directly.
And often they are correct it is indeed slow through f5!
Where do you start troubleshooting these and what to look for?
I don’t have any particular case in mind but just looking for a general checklist for troubleshooting these.
First of you can check your configuration:
  • If you use an irule that consumes too much resource (stream profile , rewriting, consomative operation …).
  • Use an adaptive TCP profil (check that naggle alogritm is disabled).
  • Check errors (LTM).
Then if you can activate Application Visibility and Reporting (AVR). This module will allow you to investigat server latency issues…
Can you give us an output of your VS configuration:
list /ltm virtual vs-name all-properties
You have this latency problem only on one VS or on multiple vs/app…
Regards
